DVD editing software
We know that video editing is not difficult, as multiple top-notch video editors are easily accessible in the industry for Windows and Mac. But what if you want to edit a DVD video or need to cut some of its unwanted parts? This is impossible with any video editor; it will require you to use a specially designed DVD editing program. But more than simply a DVD editor is needed; it should also have the capability of ripping a DVD.
Because you have to import a DVD video to the editor and then can edit it. And this is the primary purpose of our article; which is talking about 7 Top DVD editing software programs for both windows & Mac that you can use confidently.
Part 1: 7 Top Best DVD Editing Software for Windows & Mac
1. DVDFab DVD Ripper
DVDFab DVD Ripper
DVDFab DVD Ripper
DVDFab DVD Ripper can rip and convert any DVD to any video & audio format playable on any device, media player, or home theater, as well as edit DVD video with its built-in video editor.
Win Download
100% safe&clean
Mac Download
100% safe&clean
DVDFab DVD Ripper is an excellent DVD editing software program that enable you to rip and edit any copy-protected DVD discs, ISO image files and Folders according to your needs. It's built-in video editor allows you to crop, trim, merge DVD video, add effects, watermarks and subtitles, and even adjust video color as you like. You can also rip the edited DVD to various device-compatible formats like MP4, AVI, MKV, etc. or extract audio tracks from DVD.
Supporting batch conversion and powerful GPU acceleration, DVDFab DVD Ripper is capable of ripping and editing multiple DVDs at once, faster and more efficiently. Furthermore, the metadata information of the original DVD video will be automatically displayed on the media server when you play it.
💻Working System: Windows 11/10/8.1/8/7 & Mac 10.10 - 13
💡DVD Editing and Ripping Features:
  • Decrypt DVDs: It keeps updating to support the newly-release encrypted DVDs.
  • Rip DVDs: It quickly rips DVDs to more than 1000 video or audio formats with high quality. You can also rip DVD subtitles only, and add, remove, edit, or modify video subtitles.
  • Extract audio: It can also serve as a DVD to MP3 converter and editor that can cut or extract audio from a DVD in high-quality formats like MP3, FLAC, etc.
  • Convert DVDs and make them compatible: It will convert and support DVDs to play on 247 different devices like PlayStation 4, Xbox One, iOS, Android, and others.
  • Compress DVDs size: You can also compress the big DVD videos into smaller ones for playback on mobile devices.
  • Use default editor to edit DVDs: You can use 'Crop' to alter the aspect ratio and 'Trim' to remove unnecessary clips for the perfect video. You can add an image or text watermark via 'Watermark'. 'External Subtitles' allow you to add subtitles in ASS or SRT format. With 'Merge', you can combine multiple clips into one video. Adjustments to brightness, contrast, saturation, and white balance can be made with 'Brightness', while 'Audio' lets you adjust volume levels, enhance human voice and reduce noise. Lastly, 'Speed' lets you control the video's playback speed up or down.
  • Fast GPU Acceleration DVD ripping speed: The GPU acceleration support offers 50 times faster DVD ripping speed.
DVD editing software - DVDFab DVD Ripper
tips icon
DVDFab DVD Ripper also offers a lifetime-free but simplified version - DVDFab HD Decrypter - that can rip most encrypted DVD and Blu-rays to MP4&MKV format only and also edit the DVD/Blu-ray video. Both versions are installed in one DVDFab package for your easy use.
2. WinXDVD Ripper Platinum
WinXDVD Ripper platinum is a dedicated DVD editing and ripping program that help you to rip your DVD in the same original quality. You will also enjoy its use to clone the DVD to an ISO image or folder. The program does not care about the regional, scratched, or secure DVDs. There are flexible settings and support to trim, crop, cut or add subtitles to output.
💻Working System: Win 11/10 or lower & Mac Ventura or lower
  • Different DVD output formats: You can convert DVD to MP4, AVI, FLV, WMV, and other formats.
  • Edit DVDs: You can optimize the final DVD size and support to remove the CPU's burden. Apply subtitles, cut or trim video and remove black bars. It will also help you to set codec, resolution, frame rate, and bitrate.
  • Multi-core CPU support: The multi-core CPU supports delivering outstanding DVD image quality.
  • Hardware DVD encoding/decoding: It offers hardware encoding, decoding, and integrated DVD video processing. Besides this, you can back up the DVD to an MPEG2 file within a few minutes.
👎Cons:
  • There is no option for automatic cancellation online.
  • Unable to rip all copy-protected DVDs.
  • The trial version only allows for ripping up to 5 minutes of video.
  • The licensing terms for the free and platinum editions are confusing.
DVD editing software - WinXDVD Ripper Platinum
3. Freemake Video Converter
Freemake video converter is DVD editing and ripping software for Windows operating systems. There are over 20 formats for final DVDs to make accessible their content on different platforms and devices. You can also edit your DVD videos according to your expectations before ripping them.
💻Working System: Windows 11, 10, 8, 8.1, 7, Vista
  • Rip DVDs: The program supports to rip DVDs to over 20 popular formats, including MP4, AVI, MKV, WMV, MP3 and more. It also support over 50 preprogrammed profiles.
  • Decrypt DVDs: It supports to rip region-locked DVD videos.
  • Edit DVDs: You can select specific DVD titles or chapters to back up as digital files on your computer, choose audio track settings and output quality, and even remove unwanted video parts before ripping DVDs. You can also retain DVD subtitles suitable for any device. It allows you to combine several DVDs into a single digital movie without losing quality, and adjust the output file size in advanced settings to reduce the disc content of the source DVD.
👎Cons:
  • Unable to edit or rip copy-protected DVD videos except region-coded ones.
  • Unable to rip and edit a DVD ISO image file.
  • Its free version will put a watermark on the edited DVD video.
DVD editing software - Freemake Video Converter
4. Leawo DVD Ripper
Leawo DVD Ripper is also a DVD editing program for windows to convert and edit audio and video files on a DVD. The program will let you convert your videos to over 180 formats. Besides this, you can set and define the audio and video parameters, including bitrate, video codec, and frame rate, for the final result.
💻Working System: Windows 7, 8, 8.1, 10, 11
  • Rip DVDs: Leawo DVD Ripper can convert DVDs to various video formats including MP4, MKV, and HD/4K video profiles.
  • Decrypt DVDs: This software can decrypt some copy-protected DVDs, allowing content conversion into common video formats for playing on any device.
  • Ripping Speed: The software can rip and convert DVDs at 6X-faster speed.
  • Edit DVD videos: With an internal video merger and video editor, users can merge, trim, watermark, crop, and adjust video effect, even adding 3D video effect to make unique video files.
👎Cons:
  • Unable to rip newly-released DVD videos with protection mechanism.
  • The DVD ripping process takes more time.
  • The trial version only allows for 5 minutes of DVD ripping.
DVD editing software - Leawo DVD Ripper
5. Handbrake
Handbrake is a free DVD edit software for multiple operating systems. Its advanced functions make it pro software for the experts. You can use it to rip any unsecured DVD file and transcode the videos. You can use the frame rates, apply chapter markers, Deinterlacing, and sharpen the video.
💻Working System: Win, Mac, and Linux
  • Batch DVD scanning: The batch scanning feature and audio down integration are the add-on features of the handbrake.
  • Rip and edit DVDs: Like other tools mentioned above, it will allow you to edit your DVDs before ripping them. It can edit any video to MP4 or MKV. Crop or resize the DVD, backup DVDs, or remove combining objects.
  • Apply DVD subtitles: The users can add or detach the subtitles and apply multiple default presets. You can also set audio volume levels and get help with dynamic range for specific audio.
👎Cons:
  • It only support 3 output video formats.
  • It can not rip copy-protected DVDs without additional program.
  • It may not be easily operable particularly for individuals using it for the first time.
DVD editing software - Handbrake
6. Aimersoft DVD Ripper
This DVD editing program individually works great for both Windows & Mac. You can confidently utilize it to rip any video to any other supportive formats available in the program. Moreover, Aimersoft will also help you stream DVDs to popular formats like SWF, FLV, etc. There is clarity about working it via the encoded DVDs; either they are secured by region code, CSS, or other.
💻Working System: Windows XP/Vista/7/8/10 and Mac OS X 10.6, 10.7, 10.8, 10.9 (Mavericks), 10.10 (Yosemite) and 10.11 (El Capitan)
  • Rip DVDs to different formats: Aimersoft can rip DVDs to formats like MP4, WMV, m4v, H.264, 3D, and HD formats. You can finalize the conversion to F4V, FLV, SWF, etc.
  • Make DVDs compatible: You can convert DVDs to make them playable on iPad, iPhone, Android, and other smartphones.
  • Extract DVD audio tracks: Users can also detach audio tracks from DVDs and change them to WMA, AC3, MP3, and others.
  • Multiple output DVD formats: There are over 200 supportive formats and a 6-times faster conversion speed.
👎Cons:
  • Unable to rip or edit DVD ISO image file or DVD folder.
  • DVD encoding process can be quite slow and time-consuming.
  • The output video file takes up significant storage space.
7. Mac DVD Ripper Pro
Mac DVD Ripper Pro is a user-friendly software designed for Mac users to effectively edit and back up a scratched, broken, or lost DVD. With this DVD editing program, you can ignore unnecessary trailers and ads and rip only the DVD movie to high quality M4V files that can be conveniently dropped into iTunes. Moreover,  it also aids in improving battery life by converting energy-consuming DVDs into digital files.
💻Working System: Mac OS X 10.13 or higher
  • Rip DVDs: This program allows users to rip just the main DVD movie to high-quality M4V files for playback on Mac, PC, iPhone, iPad, AppleTV, Android and more.
  • Edit DVD Videos: Users can also turn on or off subtitles, upscale DVDs to HD resolution, deinterlace source material, reduce noise, reduce artifacts, sharpen videos, adjust colors, and have the option to disable automatic cropping of black borders.
👎Cons:
  • Only work on Mac system.
  • Unable to edit or rip copy-protected DVDs.
  • Very limited output formats - only rip DVD to M4V format.
  • Relatively slow DVD ripping speed.
DVD editing software - Mac DVD Ripper Pro
Part 2: How to Edit a DVD Using DVDFab DVD Ripper
Among the 7 DVD editing programs mentioned, DVDFab DVD Ripper stands out for its exceptional disc decryption, support for numerous input and output formats, diverse DVD video editing features, impressive ripping speed, and output quality. More importantly, it offers a completely free version to satisfy your basic DVD video ripping and editing needs. Therefore, we recommend you to try out DVDFab DVD Ripper. Here we will show you how to edit a DVD videos while taking DVDFab DVD Ripper as an example:
Step 1: Open DVDFab DVD Ripper and Load Your DVD Video
Download and install DVDFab DVD Ripper and click on the ripper option. Insert the required DVD Disc or click on the "Add button" to add it. Use the "Drag & Drop" feature to upload an ISO file.
How to edit a DVD video
Step 2: Choose an Output Profile and Edit Your DVD Video
Tap on "Choose Other Profile," click on "Format," and then "Video" to convert the DVD to MP4 or other formats. You can also choose to rip your DVD to iPad, Android, and many other devices. You can choose audio tracks and language, cite subtitles from DVD to SRT format, or apply external subtitles.
Go to the "Advanced Settings" and set the video and audio parameters as you want.
Then go to the "Video Edit" and click on the "Add text" option to add desired text on your DVD. The "Image" option will let you apply an image, and "Subtitle" is for adding subtitles to videos. The "Video Edit" timeline will allow you to adjust brightness, contrast, and saturation, crop or trim the video. Moreover, you can also speed up or down, and zoom in or zoom out the preview and final result. After doing all the settings, you need to click on the "Ok" button to save it.
Step 3: Start DVD Editing and Ripping Process
Finally, select where to save the video and tap on the "Start" button to start the ripping process. You will have complete control of managing the ripping process.
Part 3: Conclusion
In this article, we tried to cover the maximum best and top DVD editing programs for editing DVD videos on Windows and Mac. Some work well on Windows, some on Mac, and some on both. However, DVDFab DVD Ripping software is the overall best video editor and ripper for both operating systems. It will welcome you with its free trial of many advanced features. Using it will let you convert and edit any DVD to any other format for playback on any device.
