Despite the fact that 3GP video format is an outdated file container format and is being phased out in the new digital era, but if you still got a cell phone or device that supports playing this gradually disappearing video format, you can use DVDFab DVD Ripper, a marvelous DVD to 3GP converter software, to convert your DVD movies into 3GP video.
Here is a tip for you:
Convert DVD into 3GP: Step 1-> Download and install the latest DVDFab 9 onto your computer;
Convert DVD into 3GP: Step 2-> Start up DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD movie per the instructions;
Convert DVD into 3GP: Step 3-> Click the Profile Box (or Profile Icon) to find a 3GP profile from Device column in Profile Library, like 9300 in NOKIA section, and then press "OK" button to hit “Start” button at the Main Interface to go converting.
Note: In DVDFab 9 built-in profile library, there are only four 3GP profiles left, they are 9300 and 6630 from NOKIA section, D600 in Samsung section, and K750i/K800i in Sony section, Device column.
Software you need: the latest build of DVDFab 9
Product you need order: DVD Ripper
For more information, you can go to DVDFab DVD Ripper page.
