Top 5 Free Audio Converters
Summary: Need a free audio converter to help you covert your files to proper audio formats so that they can be played on your devices? If so, read the article and find the most powerful audio converter you want.
Everyone has favorite music and want to download it to their PC or mobile phones for offline enjoyment. But sometimes downloading music is one thing, while enjoying it is another because your downloaded files may be not compatible with your devices. So how to convert the audio to the format your devices support? There are some free audio converter introduced, such as online audio converter free download and the best free audio converter software. You are expected to find the most outstanding expert.
Table of Contents:
1. Online Audio Converter
2. Audio Converter Software
3. How to Use DVDFab Video Converter
4. Conclusion
(1) Audio Converter
For those music lovers who are reluctant to spend time installing software to convert their audios to a certain format, online audio converters are highly recommended. Now, Audio Converter is such a free online audio converter.
Pros: Audio Converter supports 300+ file formats, able to converting files to such formats as MP3, WAV, FLAC, OGG, AMR, MP2 and M4R (for iPhone ringtones). It also does well in extracting an audio from a movie or a music video.
Cons: If you choose this free online audio converter, you have to access its website frequently as long as you have audios to convert. Besides, the output directory of this free audio to mp3 converter is only limited to Google Drive and Dropbox. Sometimes confined by the network, the audio conversion progress may be not smooth, so it calls for your patience.
(2) FileZigZag
Another free online audio converter to be introduced is FileZigZag, which also supports all common audio formats like AAC, AC3, AIF, AIFC, FLAC, MP3, WAV, WMA and others. The steps on using this free audio file converter are as follows. Upload the source audio > choose the output format > convert the audio after receiving an e-mail with a link.
Pros: FileZigZag allows users to locate their audios from Computer, URL, and Google Drive, and this free audio file converter has the ability to display the available output formats targeted at your imported audios automatically. Each time you are going to convert your imported audios, usable output formats will be in front of your eyes.
Cons: If you adopt this mp3 audio converter free, there is a special requirement for the size of your audio which should be no bigger than 180 MB. Otherwise, you will be charged for the conversion. When you convert an audio to your preferred format with this online free audio to mp3 converter, you need an email with a crucial link after uploading your audio to this expert, so time is needed as well.
Compared with online audio converters, audio converter software is relatively stable and versatile. It saves users from having to logging in the online website again and again. Most importantly, such software is also free and easy for use. Users can enjoy multiple services in audio conversion without one cent to be paid. Now, let’s learn about some outstanding audio converters programs which can also convert audio to sheet music free.
(1) Freemake Audio Converter
Freemake Audio Converter compatible with Windows is good at converting most non-protected audio formats, including MP3, AAC, WMA, OGG, FLAC, WAV, AMR, ADTS, AIFF, MP2, APE, DTS, M4R, AC3, VOC and more.
Pros: This free audio converter windows supports batch conversion. More than one audio file can be converted at a time. Also, users can collaborate several audio files to one file, convert it to a new format or keep the same format, and determine the quality of converted files.
Cons: It takes more than three minutes to convert each audio if you choose to use this mp3 audio converter free. To accelerate the conversion speed, you are also expected to pay for it. Even worse, when you download this Freemake Audio Converter, another extra program may be installed simultaneously.
(2) MediaHuman Audio Converter
MediaHuman Audio Converter compatible with Windows and Mac is dedicated to converting audio files with satisfactory service. Similar to the audio format other tools support, this free audio converter mac is also capable to finish the conversion among AAC, AC2, AIFF, AU, FLAC, MP3, WAV, WMA and other formats.
Pros: MediaHuman Audio Converter with a simple and clear interface is easy and friendly for use. You only need to drag and drop the audio files to this program, choose the output format and start the conversion journey. For iTunes users, this free audio converter is able to convert iTunes songs and save them to your iTunes automatically.
Cons: This audio converter free download lacks advanced options used to set and adjust imported files compared with other audio converters.
(3) DVDFab Video Converter
You may imagine it time-consuming to download and install software, but DVDFab Video Converter, the best free audio converter, can be installed to your PC or mobile devices with just three clicks. It is compatible with Windows and Mac, so there is no limit for you to use it.
Pros: DVDFab Video Converter supports batch conversion, which enables users to convert as many audios as possible. To satisfy users’ needs in audio conversion, this free audio converter allows users to operate on such Devices to convert audios like Kindle Fire, Apple, Nook HD, AV100, Pixel 3, Desire, HuaWei, P990 Star, Microsoft and other popular or less popular tools. Supported Formats include AAC, AC3, AIFF, APE, AU, DTS, EAC3, FLAC, M4A, MKA, MP3, OGG, COPY, WAV, WMA.
In addition, DVDFab Video Converter is a good video converter as well, supporting format conversion among a wide range of choices on countless devices. Significantly, this mp3 audio converter free helps users customize their videos by adding various fantastic effects. If you want to edit a long video to a short audio, DVDFab Video Converter is also versatile to help you trim your video and convert it to the audio format.
When DVDFab Video Converter finishes converting your video, you can save the converted audio to three destinations. First, save it to the default output directory. Second, create a new folder to store your converted audio. Third, upload it to YouTube.
Now, after a detailed comparison among such qualified audio converters, with 2 online tools and three programs included, it is not hard to distinguish DVDFab Video Converter is your best choice among so many free audio converter. Subsequently, I will show you how to use this powerful tool to convert your audio files.
Step 1: Download and install this software
This progress of downloading and installing DVDFab Video Converter is very quick. Click the Free Download button based on your Windows or Mac.
Step 2: Locate targeted videos/audios
When you start DVDFab Video Converter, choose the mode of “Converter” and add your file. You can add targeted videos/audios from the options of either Local or Mobile.
Step 3: Customize targeted audios
Take an imported WMA audio as an example. Click the option of “WMA” - “Audio” - “Device” - “Format” to determine the output “Audio” format. At the same time, you can use the “Wrench Icon” to adjust “Sample Rate”, “Bit Rate”, “ Volume” and others.
If you import a video, there is another option of “Video Edit” used to trim your video as is illustrated below. After trimming and deleting your unwanted video, you can click the format of your video, here it is “FLV”, to choose your preferred “Audio” format and Device.
4. Conclusion
Have you had a full picture of how to use DVDFab Video Converter to convert your audios? As the best free audio converter, it will process your files at Turbo-Speed, providing you with a satisfactory batch conversion service. With the help of it, you can also convert your videos as well. So DVDFab Video Downloader assists you in killing two birds with one stone. For more detail about the use instructions of DVDFab Video Converter, please read How to Convert 2D Video to 3D Video.
