Top 6 Best AVI Video Converters – Convert, Output AVI Video Files
Summary: In this article, we selected top 6 best AVI Video Converters with different features that can help you convert AVI videos between video formats like MP4, MKV, WMV, and more in an easy way.
AVI is a popular video format with high video quality. There are times when you may need to convert videos in formats like MP4, MKV, WMV, etc. to AVI for playback on a particular device, and vice versa. Some people believe that it is troublesome to convert a video, but in truth it is an easy job that only requires several mouse clicks if you have meet a handy AVI video converter. The market is flooded with a variety of AVI video converters, so which one is the best one? Here in this article, we have selected top 6 best AVI Video Converters with different features. Some of them are complete free, some of them are online converters and some of them are powerful and full-featured. Now let’s take a quick look.
1. DVDFab Video Converter
DVDFab Video Converter is a professional, powerful, and full-featured AVI video Converter that can convert nearly all videos to AVI formats and convert AVI format to formats like MP4, MKV, FLV, etc. , all kinds of devices like Apple, LG, Samsung, etc. and various 3D and 4K videos. The interface of this AVI video converter is intuitive and user-friendly, so it is easy to use, and you only need to drag and drop the source video, choose a profile format and click the “Start” button.
It also provides you many advanced customization tools. At the “Advanced Settings” panel, you are able to set the codec, frame rate, resolution, video quality and more parameters. With the built-in editor, you can preview the video, rotate, trim, and crop the video, change the aspect ratio, add watermark and subtitles, and adjust the picture values like brightness, contrast, and saturation. You can also choose the audio track and subtitles you want if your video source has multiple audio/subtitle tracks.
DVDFab Video Converter features a lighting conversion speed due to its employment to the latest hardware acceleration technology. For a large video, it can complete the conversion in a few minutes. Moreover, it can output video with high quality. If you want a 100% lossless video, you can choose MKV Passthrough or MP4 Passthrough profile.
Click here to learn how to convert video with this AVI video converter.
Free Download DVDFab Video Converter for Windows
Free Download DVDFab Video Converter for Mac
2. Online-convert.com
Online-convert.com is an online AVI video converter with many advanced options. It can convert FLV, MKV, MOV and more to AVI and convert AVI to various video formats and devices. It supports not only video files but also video links from video websites like YouTube, Vimeo and more. There are a lot of optional settings for you to customize your settings. You are able to change the screen size, video bitrate, audio codec, frame rate, etc. and to cut and crop the video. The maxim file size it can freely convert is 100 MB, so if you want to convert larger video, you need to buy their service.
3. OnlineVideoConverter.com
OnlineVideoConverter.com is another online AVI video converter that allows you to convert AVI video without installing a program on your computer. It is 100% free. It can convert many videos to AVI and convert AVI to many video/audio formats like MP4, MPG, MOV, MP3, AAC and more. It is touted as a great online video converter because its high quality outputs and fast conversion speed. Same with Online-convert.com, it enables you to convert both URL links and video files. But it doesn’t contain so many advanced options like the former, and it only allows you to choose the video quality and set the length of the converted video. Its allowed max file size is 3072 MB.
4. Any Video Converter Free
Any Video Converter Free is a free AVI video converter that can convert between AVI and other video formats and devices easily. It claims it supports 100+ inputs and 160+ outputs. It is also a free audio CD ripper which can rip audio tracks from CDs and convert them into all sorts of audio formats. It also can be used as a DVD burner to burn videos to DVD discs. It has some advanced customization tools for you to trim, crop, and rotate videos, join videos into one, add subtitles, audio tracks, watermark and special effects. The parameters like video codecs, dimension, bitrate and more also can be modified. However, its conversion speed leaves a bit to be desired.
5. Movavi Video Converter Premium
Movavi Video Converter is a fast AVI video Converter that can convert AVI videos between 180+ different media formats, including some picture formats like GIF, JPG, and more. It also provides over 200 presets for popular devices. It comes with some essential editing tools, though not so many as DVDFab Video Converter, you can use it to rotate, crop, and stabilize your video clips and fix the video quality. Same with DVDFab Video Converter, it uses hardware acceleration technology to boost its conversion speed.
6. WinX HD Video Converter Deluxe
WinX HD Video Converter Deluxe is a simple-to-use AVI video converter with some advanced features. With its rich profile formats, you can convert video files to AVI formats and convert AVI to other video formats, like convert AVI to MKV, AVI to MP4, etc. There are also 410+ preset profiles for you to convert AVI videos to Apple, Android, Microsoft, Chromecast, etc. devices. Its editor allows you to trim and crop video, merge multiple videos into one, and add external subtitles. It contains a unique feature that lets you create slideshow from your JPG/PNG/BMP photos. Its weak point is its slow conversion speed. It may take more than a half hour to complete a conversion, while DVDFab Video Converter does it in a few minutes.
Thanks a lot for walking with me here. Now we have shown you the top 6 best AVI video converters. What do you think? Choose one and try it yourself. I hope you have a good experience in using these AVI video converter!
