How to Convert VCR to DVD Fast and Well 2020
2020-03-21 00:14:33     Posted by Amanda; Starry
8593
Summary: With the discontinuation of VHS VCR makers in 2016, a vast majority of disc lovers turn to DVDs, few to Blu-rays. This article introduces you two VCR to DVD converters to convert VCR to DVD for playback on disc player.
If you have a box full of old home VHS tapes that contain your childhood memories, it would be wise to convert them to digital formats with VCR to DVD converters for the ultimate goal of longer lifespan of past moments. If you aim to transfer VCR to DVD, you are in the right place. This post will take you through several VCR to DVD converters to fix your problem.
Quick Navigation
1. VHS v.s VCR
2. Diamond Video Capture vc500
3. Roxio Easy VHS to DVD 3 Plus
4. Final Thought
Before getting down to business, let’s look at the difference between VHS and VCR, which will give you a better clue to seeking the right VCR to DVD converters.
1. VHS v.s VCR
VHS (Video Home System) is an analog recording format developed by JVC in 1976, which adopts a half-inch wide magnetic tape to record up to six hours of video content with 240 lines of horizontal and 486 lines of vertical resolution, as well as a stereo sound track. This format was designed to be compatible with a wide range of video cameras and cassette players due to its cheap price and easy-to-use feature, and became the dominant video standard in the world market by the 1990s.
VCR (Video Cassette Recorder) is any device able to play and record videotapes that are pre-imported into cassettes. Actually, VCR was the larger versions of later popularized VHS tapes and also used magnetic tapes to record the videos.
It follows that VHS is a videotape cassette format and VCR is the name for a type of player. But in reality, with the demise of Sony's Betamax format for home videocassettes, virtually all VCRs exclusively play VHS tapes, and virtually all videocassettes are in the VHS format. Even so, nowadays there is still need to convert VCR to DVD with professional tools.
Now let’s get a quick glance over the following three VCR to DVD converters.
This VCR to DVD converter is a hardware plus software combo that works on PC and supports up to Windows 8, which has been adequately tested and verified by gadget freaks and testing sites. The major pros about the device are that it comes with analog pins that connect to your VCR player or VHS output at one end and the other end connect to the computer or laptop via a USB port at the other end. All you need to do is play your VHS cassette and get it recorded at the other end of the device into your computer. The whole process can take some time depending on the length of your cassettes. Once done, the files are saved in all major file formats (MPEG1, MPEG2 up to MPEG4) that are supported and used widely by video and media players. These files are now available in digital format on your hard disk. What to do next is use a DVD maker to convert the digital file into a menu driven tagged DVD, add custom designs, audio tracks and subtitles, create chapters and so on from VHS or VCR to DVD. This is a good way to convert VCR to DVD.
Diamond Video Capture also comes with its own DVD creator with editing options and thus allows you to transfer VCR to DVD. However, if you are using one of the latest computers, you can benefit more by DVDFab DVD Creator that applies the latest Intel Sync and other processor to speed up the conversion process without any loss in quality of audio or video.
Another reason to consider this VCR to DVD converter is that Diamond Video Capture is also universally compatible with any video capture software, so you can capture it using other software that can render the captured video into a digital file much faster with hardware acceleration. In a custom test, it took 15 hours to burn a single 40 min from VCR to DVD disc.
This is also a hardware VCR to DVD converter from analog to digital along with bundled software to capture video from the laptop or computer screen and then bundled with a DVD burner as well. It is universally compatible with any other video capture software, and most obviously once the video has been rendered, you can easily convert VCR to DVD and then to file versions for most widely used MP4 or other versions for your DVD, or just play it on your smart phone. Nevertheless, the output format is limited to only three options, while many others have up to 7 different options. To make up for this downside, this VHS to DVD converter gives the options to edit the video before burning to a DVD.
However, the software bundled with the VCR to DVD converter is of not much use compared to the likes of DVDFab DVD Creator that supports multi-threading and GPU acceleration to quicken the whole burning process manifold times. The video rendering is also enhanced from 15 hours to around 5 hours using software like Handbrake that supports multi-threading and GPU acceleration also.
Final Thought
From this post, you might have understood how to convert VCR to DVD with the optional VCR to DVD converters. Whichever you choose, you are highly recommended to transfer VCR to DVD with DVDFab DVD Creator once you have converted VHS to regular video formats. Besides, if you know how to create a DVD menu, your created DVD will become much more professional and stylish.
Apparently, one good thing about such devices is that you can record any copyrighted material, since they allow you to convert the VHS or VCR contents from the laptop by capturing the recording playing on the screen itself. This is akin to making the video once again from scratch. It is not trying to decrypt the video file on the VHS cassette, but playing the analog video file and convert VCR to DVD by first to digital and transferring to the laptop via the USB port. It is as simple as it sounds.
The best DVD ripping software that can quickly rip and convert a DVD to any mainstream audio & video formats for playback on PCs, portable and mobile devices.
You May Need Other Tools
DVDFab Blu-ray Creator
A high-end DVD movie maker software to burn all sorts of videos into DVD discs or to be standard DVD ISO files/folders
DVDFab Blu-ray Copy
A powerful and professional Blu-ray creator and burner software that can burn all sorts of videos
DVDFab DVD Copy
A well-received DVD copy software to read and backup a DVD to any blank disc, as ISO file or DVD folder
