How to Burn MTS/M2TS Files to DVD in 2024
Summary: MTS and M2TS files are video file formats utilized in high-definition digital devices. However, there are instances where we may want to convert then into DVD format for greater accessibility and convenience. This article will show you how to burn MTS/M2TS files onto a DVD using the top-rated DVD creators.
Burn MTS/M2TS and other 200+ formats to DVD discs/ISO files/folders
Output high-quality DVD video for immersive viewing experience
Create a DVD menu with various templates support
GPU-accelerate video to DVD burning speed
Part 1. What is an MTS/M2TS File?
MTS and M2TS files barely have differences. MTS file format is a file extension for videos shot by high definition digital video cameras. And if you export an MTS file from HD camcorder to windows/mac, then its file extension will be changed to the M2TS file.
The MTS file format and M2TS file formats are popular due to its widespread usage in camcorders with a super high resolution such as 1080p and 720p. It was specifically for large screen viewing by transferring your video clips through direct streaming or through drives plugged into the monitor or TV.
Part 2. Why Do We Need to Convert MTS/M2TS Files to DVD?
Despite their popularity, MTS and M2TS files are only supported by a limited number of media players. Additionally, storing these files can gradually slow down your computer over time. A practical solution is to convert and burn these files to DVDs, not only freeing up your computer's resources but also enabling you to enjoy these videos on a larger TV screen. Hence, the need for an efficient MTS-to-DVD conversion process arises.
MTS is a universally adopted format used by major brands like Sony, Panasonic, Philips as well as smaller local manufacturers. As such, an MTS-to-DVD converter is typically included in most video converter tools available both online and offline. In this context, we will recommend some top-notch tools that excel in terms of user-friendliness and speed.
Part 3. Top Three Burners to Burn MTS/M2TS File to DVD
DVDFab DVD Creator
DVDFab DVD Creator is able to burn your MTS/M2TS video files into a blank disc or save them as ISO image file or foler on your PC's hard drive. It also supports more than 200 popular video formats as input. The output DVD video and audio with high quality will bring you an immersive watching experience.
Another distinct feature of this burner is that it offers a built-in menu library with templates on different subjects. You are also allowed to customize th elements and widgets inside the menu templates, such as background art, thumbnails, text settings, and playback buttons.
Its under-the-hood improvements include full support and compatibility with the most recent Intel Core processors via Intel Quick Sync, which uses its in-built GPU for video processing. It also supports NVIDIA cards and can use GPU acceleration to speed up processes if you have one. In essence, this DVD maker reduces the load on the CPU, speeds up the burning process by up to 30 times.
And, furthermore, while you convert MTS to DVD, you can also watch movies on your laptop or browse the internet and so on without worrying about the freeze or hangs. Thus, it offers multitasking capabilities even while doing the heavy stuff.
Note: DVDFab also features a Blu-ray creator module to help your burn MTS/M2TS videos to Blu-ray disc, ISO file or Folder.
Tutorial: How to burn MTS/M2TS file to DVD with DVDFab DVD Creator?
Step 1: Launch DVDFab Creator program and load the source MTS/M2TS videos
Step 2: Customize your disc with built-in templates
You can make Advanced Settings, Menu Settings, and select audio tracks and subtitles from this menu. By selecting Advanced Settings, you can customize the volume label, output, and video quality. Menu Properties and Playback Mode are also options.
Then, click Menu Settings button to access the free built-in DVD menu creator. Select a stylish menu template and customize the elements and widgets within this menu.
Step 3: Select a directory and start the burning process
Wondershare DVD Creator
Wondershare DVD Creator does not need to convert the MTS file formats before burning those files to a DVD using a burner like Nero. You can directly add the MTS/M2TS files or other 150 + video formats and burn them to DVD or Blu-ray discs. This is available for both Windows and Mac. But Blu-ray disc authoring is only available on the Windows version.
It takes a while to burn an MTS file to DVD, and even more if the file is too large. There are also different formats for DVDs depending on the output media file type, such as MPEG-1, MPEG-2, MPEG-4, or Blu-ray H.264 encoded media files, and so on.
This DVD creator also allows you to do all the editing stuff and finally asks you to insert a single-layer 4.7 GB or double-layer 8.5 GB DVD to start the burning process. Finally, you choose the options for DVD Folder, DVD Disc, DVD media file, or ISO and hit the Burn button.
There are things like the preview, editing like tripping, cropping, changing the quality of brightness, adding subtitles, watermarks, audio tracks and so on that need a lot of computing resources like memory RAM and CPU.
Convertio (Online Video Converter)
If you wish to convert MTS files to DVD online, Convertio is an effective tool to do your a favor. You can simply upload your MTS or M2TS video file by choosing them from your computer, dropbox and Google Drive. This is an additional step, but it might be worth if you don't want to worry about installing anything onto your system.
However, you can only use this online tool to transform your MTS or M2TS video files into the DVD-compatible VOB format. It also doesn’t have the ability to directly create DVD video format which requires specific DVD authoring process like creating menus, chapters etc. You may need to use a separate DVD authoring software for that purpose after converting your video file into a suitable format using Convertio.
Since you have learned so much about MTS and M2TS files and the tools to convert or burn them to DVD, you must have made up your mind which one to use. If you don’t, you can try DVDFab DVD Maker. Like we have explained in this post, this software does have a lot of features that help you burn MTS and M2TS videos to DVD discs, and you're probably hooked by them.
