WinX DVD Author Review and Best Alternative
Summary: There are a number of users who are lately facing issues while using WinX DVD Author. And the help section is also not of much use, as per many frustrated users. Hence, in order to get you out of this dilemma, we will be offering you the best alternative to WinX DVD Author 6.3.6. Read below to know more about the WinX DVD Author review.
- • Burn videos into DVD discs/ISO files/folders
- • User-friendly and easy-to-use
Everything About WinX DVD Author
WinX DVD Author is a well-known DVD burning tool that lets users watch DVD files on any device. The software offers over hundred optimized conversion options that include basic file formats along with customized rips for devices such as tablets, gaming consoles, and smartphones. The tool rips without consuming any time and at the same time offer high-quality output. Users will find it hard to spot the difference between the ripped version and the original DVD.
Apart from this, the software lets users rip raw DVD files such as disc images and Video TS folders. This feature is not present in most of the alternatives available in the market. WinX DVD Author provides high-quality rip features that allow users to fine-tune their files by altering the technical facets of the video such as frame rate, aspect ratio, and bitrate. Moreover, the tool comes with a simple video editor that allows users to crop video, edit subtitles, and trim footage.
Features
- Support all types of DVDs
- Fast DVD ripping speed
- Backup DVD without any quality loss
- Uniquely for intractable DVDs
- Digitize and rip the latest DVD
- DVD to MP4, AVI, mobiles
- 1:1 DVD to PC, ISO image
- Crop/trim DVDs; subtitle
- Main title content copy, full title copy
- Backup DVD to an MPEG2 file in 5 minutes
- 1:1 clone DVD to ISO image, DVD folder
💡How to burn a playable DVD on Mac?
How to Use WinX DVD Author?
Now that you have had a look at the features, let us see how to use WinX DVD Author. Follow the below WinX DVD Author instructions to know how to use it.
- Download and install the tool on your PC. Next, launch the tool.
- To add videos, click Add File (+) button.
- In addition to this, users can delete loaded videos, move up or down, and add subtitle files.
- To go to the next step, click the">>" button.
- Click Chapter Menu and Title Menu on the next screen as well as the TT button to add text for the chapter and title menu.
- Next, edit it by double-clicking the text.
- Users need to select their output video format, file folder, and click the Start button.
WinX DVD Author Problems
Even though the tool is useful in many ways, WinX DVD Author problems have not allowed users to leave in peace. Here is a list of problems that users face while using the tool.
- Some users have complained that WinX DVD Author has stopped working.
- In addition to this, WinX DVD Author won't burn and the tool is buggy most of the time.
- Users have also complained that WinX DVD Author does not recognize the DVD burner.
Best Alternative to WinX DVD Author
Seeing the above issues faced while using WinX DVD Author, the need for an optimal option is felt. And DVDFab DVD Creator is the best option in the market. This tool is the best alternative if you are looking to create ISO, DVD disc, or folder from any popular video format.
How to Use DVDFab DVD Creator?
Download and install DVDFab
Launch the tool and select Creator from the option bar present at the top. Then load the source files by clicking the "Add" button or simply dragging and dropping it into the main page.
Customize the output DVD
When the source video is uploaded, Click the "Advanced Settings" button, you will be able to elect the output DVD size, name the output DVD, and configure the Menu properties and playback mode.
Then click "Menu Settings" to create DVD menu from a variety of templates and customize all its elements as you like.
Click the start button
Choose the output folder in Save to Path, and tap the Start option to start burning your DVD.
As per our recommendation, DVDFab DVD Creator is the best DVD maker available in the market right now.
WinX DVD Author is free to download but users need to shell money to use it after the free trial period is over.
Having said that, we just had a look at the WinX DVD Author review. You saw the features and the WinX DVD Author problems. Next, we saw that DVDFab DVD Creator is the best option for WinX DVD Author. Certainly, there are also open source DVD burner tools available in the market. However, this article does not delve into them. You can opt for any of these tools that align with your specific requirements.
